radfordc wrote:If deadstick, off-airport landing skills are needed (and it is evident they are) what is the best way to acquire those skills?
Here's a great way you can get a lot of "dead-stick" practice: find a nearby glider club/operation, join for a season, and at least get to the point where you Solo.
Glider training involves a lot of the following:
- Practice landings with an "engine-out" - teaching you how to estimate your glide range, approach angle, and making maneuvers in order to safely hit your desired touchdown point.
- Using slips to alter your glide-path on final approach - in gliders this is in case our spoilers malfunction; but its great for powered flying when you need to make a short approach or alter your glide-path without slowing up the airplane in an engine-out scenario.
- Rope-breaks during the tow - this gives you the "startle factor" of a failure on climb-out and trains you to lower the nose, establish good glide speed, assess your chances to return to the airfield, and maneuver for that landing.
There's more to flying gliders/sailplanes, but just getting to solo will add a lot more skill to your everyday Sonex flying!
NOTE: If possible, train at a glider club/operation that does
not use 1950's Schweizer gliders (as they fly like box-kites and require giant control inputs; very different from other gliders and from a Sonex). Places that offer training in Blanik gliders, Grob gliders, or ASK gliders will feel a lot more like "normal" airplanes (as well as flying like modern gliders).
Finally,
please do not hesitate to message me if you want to know more, or give this a try! I love helping folks get into gliding/soaring, I help organize mentorship events and competitions in the US each year, and I know many of the clubs and commercial operations around the US (as well as a few in the UK, France, and NZ).
--Noel
Sonex #1339
ASG-29
