Two lever operated 1/2” Hegars, one master for each wheel caliper, seems an acceptable way to go. I am a little unsure if I should either adapt the long Sonex brake handle, or put in a complete Hegar setup. Your thoughts on this?
Kai
Zack wrote:The larger spinner and redesigned cowling will really change the profile of the aircraft. Mace Aviation created a 7 page PDF slide show I can share with other views, but I'm not sure the best way to post it.
Zack wrote:Here is the cowling attached.
Zack wrote:Zack wrote:The larger spinner and redesigned cowling will really change the profile of the aircraft. Mace Aviation created a 7 page PDF slide show I can share with other views, but I'm not sure the best way to post it.
Skippydiesel wrote:I am just at the stage of using;
The Sonex supplied vertical split cowling, suitably modified to fit my set up
OR
Making a cowling from scratch.
My Sonex has a Rotax 912 ULS driving an an Airmaster CS 3 blade prop (large spinner/back plate).
Coolant radiator is mounted just below lower firewall and will be cooled by cowling exit air - cowling will need to be a good fit to facilitate cooling system.
Oil cooler mounted directly behind right cowling inlet(may over cool)
Size of inlets will be critical to achieve adequate ground ops cooling while not creating undue drag in flight.
Any additional information you can supply will be very much appreciated
