Area 51% wrote:And for the rest of us ... [snip] use a timing light.
Area 51% wrote:Short of having to acquire a timing light to accomplish the task, (seems I remember having to purchase more than one specialized tool to build the plane in the first place) I see nothing more convenient about flying the test subject to get initial readings, removing the cowl, adjusting a fickle trigger magnet, replacing the cowl, take the plane back up to check the adjustment......then rinse and repeat as necessary or until frustration sets in.
As far as "fiddling with a running engine", the only "fiddling" I'm aware of while the prop is spinning is pulling the trigger on the timing light. To be fair, it should be considered a two-man operation, with someone you don't particularly like holding the timing light, and the timing marks should be on the flywheel and not on the prop hub. I doubt there is a single case in which the engine was started for the first time at the end of the runway and flown during the initial start-up. Point being, there are multiple opportunities to check and adjust before any first flight of an engine. Ground running needs to be only long enough to verify the pointer and mark line up (or don't).
Since one of the things we're trying to accomplish here is to match the secondary ignition to the primary to keep advanced timing from damaging the engine during high power output, it seems problematic that full throttle operation during takeoff and initial climb are required to get to a safe altitude for the CHT/EGT experiment. A timing check with a light can be accomplished at an idle and well in advance of WOT.
Rynoth wrote:Any guides on how to setup and use a timing light on the Aerovee?
Bryan Cotton wrote:We set the secondary ignition timing today. It was waaaay advanced initially.
I went and set the prop so the top magnetron was lined up for firing, like in the initial setup for setting the secondary ignition statically. Then I painted a line on the flywheel and one of the gear teeth, and drew a line to match on the case.
We ran the engine with the timing light inductive clamp hooked on a magnetron plug wire. I had to erase the line with acetone and move it so they lined up when it was running and the timing light fired. Once I had that line good for the magnetrons, then we swapped the inductive pickup to the secondary ignition plug wire. It took a lot of tries. I think we really need a good way to hold the magnet ring from moving while you loosen, tighten, and move the prop. But, we finally got the secondary timing set pretty good.
I can't shut off the mags yet, but the drop when I turned off the electronic ignition was 40 RPM. Seems like a good start.
I bought this timing light from Harbor Freight:
https://www.harborfreight.com/timing-li ... 40963.html
It has a stupid feature that lets you adjust when the light fires. I recommend duct taping it to zero, else you will bump it and wonder what in the heck is going on.
Users browsing this forum: Google Adsense [Bot] and 14 guests
