Stu AI7AN wrote:This High Wing design looks like a home run! Was strongly considering acquiring a Sonex kit within the next 12 months, but will I now decide to wait? Tempting, because I REALLY prefer high wing, particularly when it has a green house window above. I may not be quite that patient, but it remains tempting.
My PLEA to Sonex would be to make weight allowance for the Corvair power plant. I would still likely respectfully pursue it regardless in whatever version I wind up with, but this would be the perfect opportunity to incorporate the ability to do so with factory blessing. For my preferences this High Wing would seem to be as close to experimental perfection as could possibly be achieved.
Stu (N. Central Idaho)
GraemeSmith wrote:In all the "what if'ing" and "wishes" - remember it has to make the current LSA limits of:
Maximum stall speed - 40knots
Maximum speed - 120 knots
Maximum Gross - 1320lbs.
And while there are interminable press articles about new bigger weight limits "just around the corner" with new LSA specifications - they have been "just around the corners" for quite a few years and counting.
So I'm not surprised that Sonex are aiming at 1,320lbs at this time.
Note the minimum hp of 100 - needed to get the power loading into an acceptable spot with that 1,320 maximum gross.
Matt541 wrote:Stu AI7AN wrote:My PLEA to Sonex would be to make weight allowance for the Corvair power plant. I would still likely respectfully pursue it regardless in whatever version I wind up with, but this would be the perfect opportunity to incorporate the ability to do so with factory blessing.
Based on my conversation with Mark, I wouldn't hold your breath on a factory approved installation of the Corvair engine in this variant or smaller Sonex aircraft.
Eric W wrote:Ok, this announcement got me to find this forum. I plans built a Sonex TD / 3300 in 2005-2008, flew it for about 4 years, and moved on. Now I'm more interested in the easier getting in/out aspect of a high wing, and greater headroom sounds good as well. While we're making our preferences known, I'd rather not carry the weight (or pay for) extra wing removal features. For me, the under 8' width would be great for the one time I bring it from where I'd build it to the airport. After that, wing quick removal is just added weight & cost I don't need. So if you're looking at the bulkheads and paddles like the Onex, a longer pushrod / delete paddles option would be my preference.
I haven't kept up with the LSA proposals, but at this point, I'd consider one of the UL350's and a cruise prop, operate w/ Basic Med if needed and not worry about the current LSA speed limitation.
There's definitely a market for high wings that aren't STOL.
DCASonex wrote:Better ground visibility might be a real benefit in avoiding cleaning the interior. When taking someone on a local flight here, I used to fly over the falls at local state park and to provide a better view would tip the plane to put a wing down and then slip to hold in that position. Had two passengers loose their lunch when doing that.
As to fitting 29" bush wheels, that would make it a swamp buggy with wings.
Users browsing this forum: Bing [Bot] and 45 guests
