Mike53 wrote:Looking for some help with my high oil pressure reading on my Hummel engine. Engine has a little over 4 hours and the last time I started it to get the oil distributed in the engine I noticed the oil pressure climbed to 95 psi
at which point I shut it down.
Scott,
The Oil Pressure has been marginally high from the start. I bought another VDO transducer and It produces a slightly higher reading. Last time up after a touch and go the oil temperature was about 180 but the oil pressure went to 80 PSI on takeoff. Is there an easy way to bring the pressure down a bit? Or ..., should I just not worry about it? As a side note, while on the ground I can bring the pressure down by goosing the engine.
I wouldn't worry about the high oil pressure. You can lower it by changing the spring on the rear relief valve.
WesRagle wrote:The thing that bothers me most about it is that high oil pressure probably results in higher oil temp.
pappas wrote:If it never goes over 100, you shouldn't have any problem and shouldn't burst your oil cooler.
