Similarly, the aircraft’s gross weight should be below 1150 pounds if equipped with an engine producing 100 hp or greater or 1100 pounds if the installed engine produces less than 100 hp. A Sonex with a licensed gross weight above those thresholds will be disqualified from the Light Sport category.
GraemeSmith wrote:Kitplanes Magazine's Kate O'Conner's take on buying a used Sonex:
https://www.kitplanes.com/buying-used-sonex-waiex/
Bryan Cotton wrote:From the article:Similarly, the aircraft’s gross weight should be below 1150 pounds if equipped with an engine producing 100 hp or greater or 1100 pounds if the installed engine produces less than 100 hp. A Sonex with a licensed gross weight above those thresholds will be disqualified from the Light Sport category.
Is the second sentence actually true? That would imply that too low of a power loading would disqualify an aircraft from being an LSA. That doesn't make sense.
