pappas wrote:I used the Dynon Static port kit. The ports are 1 inch below the turtledeck longeron and 1 inch in front of the first bulkhead aft of the baggage compartment. I installed them in the same place on my RV-8. Sonex doesn't really give us any guidance and testing an airframe for "undisturbed air" during flight is not practical for most of us. Additionally, some say that you shouldn't place them on a fuselage like ours that tapers as that is not directly parallel to the airflow. However, Vans has been doing that for 30 years with no ill effects. So I did too. Make sure you get the system calibrated though. Another thought. Cessnas have the ports in front of their doors in the panels that are parallel with the airflow in level flight. The B models have that option as well and would be a good choice if you place your ADAHRS behind the panel or in the front of the fuselage somewhere. Mine is in back.
Users browsing this forum: No registered users and 41 guests
