Installing prop bolts with the aerovee spinner
Postby Spaceman » Tue Sep 14, 2021 9:25 pm
How do you guys torque your propeller bolts? The counterbores on the spinner aren't big enough to fit a 1/2" socket from what I can tell, so how do you hold the bolt while you torque the nut? Am I missing something obvious?!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Re: Installing prop bolts with the aerovee spinner
Postby Sonex1517 » Tue Sep 14, 2021 10:06 pm
Chris, when I had my AeroVee with that spinner I just looked for the thinnest sockets I could find and ground a bit off the edges to make it fit.
Others may have more elegant solutions.
Postby pappas » Tue Sep 14, 2021 10:15 pm
I concur with Robbie. Individual, cheap, hardware store, bargain bin, deep socket might work. But you still might have to grind some.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby Bryan Cotton » Tue Sep 14, 2021 10:36 pm
I ground one down.
Postby Spaceman » Tue Sep 14, 2021 10:39 pm
Ah ok I'll just do that! Thanks!
Chris Paegelow
Spaceman
Postby DCASonex » Wed Sep 15, 2021 8:23 am
Good quality 3/8" drive sockets should fit. Cheap ones with low grade steel and poor tolerances tend to have heavy walls.
Postby GraemeSmith » Wed Sep 15, 2021 8:28 am
DCASonex wrote:Good quality 3/8" drive sockets should fit. Cheap ones with low grade steel and poor tolerances tend to have heavy walls.
^^^^^THIS^^^^^^
Graeme JW Smith
GraemeSmith
Postby Area 51% » Wed Sep 15, 2021 10:49 am
I use a 1/4in drive socket with an adapter. $2 at the flea market.
Users browsing this forum: autopro and 63 guests
