Maybe I can dish those washers out and maybe use an extra washer or two and longer bolts
Area 51% wrote:I too had fender washer clearance issues, but lacked the talent of Bryan to manufacture dished washers. I did come up with a "stepped" washer (for lack of a better term). I'm sure I was enlightened by someone on this site. I have no idea where I got them from, but the part number is 3068-03 and the description is 3/16 inch Rod End Retaining Washer.
I can email you a picture of the bag and the washers if you like.
Bryan Cotton wrote:Here is my solution. I bolted a few standard washers to either side of the fender washer. I then got a socket just slightly bigger on the OD than the fender washer. I pressed on the bolt and cupped the washer. No more interference but the washer will still retain a failed rod end.
Users browsing this forum: Bing [Bot] and 11 guests
