What stops the ailerons depends on each set-up. To be sure, however, the seat pan is not intended to be a stop. If the seat pan interferes with proper aileron travel after the wings have been installed and aileron rigging is underway, the seat pan must be trimmed.
There are stops built into the aileron pushrod pivot in the wing. See View G-G on drawing W02. This initial setting of the bellcrank will play a large role in your rigging.
Sometime the counter weight is a gentle stop at the extreme end do the control travel.
Until the wings are installed and rigging has begun it is impossible to say how far your ailerons will travel. They should not stop on the lower, aft spar, but they may come close.
I’d say if you want to set up the servo now, make sure it can move the stick fully side to side within the seat opening but plan on it being limited by something else once the wings are installed and rigged.
