Engine mounts sagging
Re: Engine mounts sagging
Postby mike.smith » Sat Dec 19, 2020 10:23 pm
estegen@outlook.com wrote:Hi , has anyone had success with polyurethane engine mount bushes for a aerovee .
I did when I had someone else make them for me. Whatever polyurethane was used worked well. When I tried to make them myself the urethane I used didn't hold up 10 hours before beginning to fall to pieces. So be very careful about what urethane you use. And monitor your mounts often and carefully for a while after. I'm using stock AeroVee mounts at the moment.
Postby bvolcko38 » Mon Dec 21, 2020 10:22 am
Does anyone have the physical dimensions of the rubber shock mounts?
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby bvolcko38 » Thu Aug 19, 2021 10:39 am
I bought a polyurethane round bar from McMaster Carr, 80 durometer, just like the factory bushings. I made 8 bushings to the same dimensions as the factory's. They have been installed and flown with for over 2 months now and zero sag. Vibration seems normal. The original bushings started sagging the day i mounted the engine. It took about 2 weeks to fit the cowl after mounting the engine and I noticed the creepage. 2 years later the bottom bushings were worn through and just started to get metal to metal contact between the backplate and the motor mount.
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby pappas » Thu Aug 19, 2021 12:28 pm
I had to replace motor mount bushings once on my 3300 powered Waiex in 2007. I went with the harder ones from sonex and did not have any additional sagging at the time I sold it in 2009.
However, because I am aware of the sagging issues everyone has; when I built my current Waiex Turbo in 2019, I simply wrapped hose clamps around the bushings and tightened them down like usual. 2 1/2 years later and 125 hours and my engine is in the same place it was the day I hung it.
I don't know if that will last, but my cowl spacing is the same as when originally fitted. Of course, now that I have spoken about it, I expect to find my motor on the floor when I get back to the hangar.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby bvolcko38 » Fri Aug 20, 2021 8:49 am
I did the hose clamp thing as well, to no avail. The rubber compound is not right. It flows over time. So far the polyurethane seems to be working nicely. Time will tell. That's why they call this "experimental"
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby pfhoeycfi » Fri Feb 11, 2022 10:02 am
pappas wrote:I had to replace motor mount bushings once on my 3300 powered Waiex in 2007. I went with the harder ones from sonex and did not have any additional sagging at the time I sold it in 2009.
Did you use 1/2" band clamps or something less?
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby Bryan Cotton » Sat Aug 06, 2022 5:29 pm
Five years static, an hour of ground running, and 1.7 hours in 3 flights so far. Poly bushings seem good.
Edit: these are Super Pro SPF2092BK bushings. Available in the US and Australia it would seem. Some of the old links are broken but if you search for "Super Pro SPF2092BK" you will find their USA or Australia website, plus ebay sellers and so on.
Postby Bryan Cotton » Tue Dec 27, 2022 7:57 am
Bryan Cotton wrote:Five years static, an hour of ground running, and 1.7 hours in 3 flights so far. Poly bushings seem good.
43.6 hours and I'm still happy with my Super Pro bushings.
Postby tps8903 » Sun Feb 26, 2023 2:23 am
Was there a change in engine position when you swapped from factory rubber to the Super Pro Mounts?
Chris Morris
Sonex N998PC - SOLD!
Sonex #1732 - Aerovee Turbo
Central Florida
tps8903
Postby Bryan Cotton » Sun Feb 26, 2023 10:11 am
tps8903 wrote:Was there a change in engine position when you swapped from factory rubber to the Super Pro Mounts?
I went right to these mounts during the build, based on this thread. I tweaked the engine into alignment by adding washers and turns on the nut.
Users browsing this forum: Bing [Bot] and 35 guests
