by CaseyCooper » Fri Aug 13, 2021 11:38 am
Kai,
I experienced the same issues. I’m actually in the process of redoing my lower portion of my cowl to reduce and streamline my cooling system. I was expecting high temps since in the summer we operate up to 120f (48c) at max and I set it up too well. I’m running a stock 912 radiator and a aftermarket oil cooler in succession in my scoop. When flight testing in December, 65f (18c), I would see 130f (54c) cht and 100f (38c) oil. Which surprisingly a lot of people run those numbers all winter long here. Not saying you should! But people do. We always want around 200f (94c) right? So all I did for a temporary solution was put duct tape across my radiators to bring my temps up. During that time I bought a oil system thermostat that operates at 10% capacity until reaching 180f (82c), then it opens accordingly to maintain temps. I installed it and removed my tape and that in turn brought up my cht’s and they remain an equal temperature to each other in either summer or winter. As a plus, my warm up times went down to about 5 minutes total, when before I would sit for about 10-15 to warm up. I still need it warmer, we want to see 200f (94c) every once in a while to steam off the water and impurities in our oil. So my new cowling should help bring those temps a little higher, I’m also going to install adjustable louvers just to fine tune in flight with changes in atmosphere and terrain.
As a recommendation to you, so you don’t have to manipulate your mechanical integrity, I would do a pass of duct tape on each radiator and go fly it and add or remove tape until you see temps reaching where you’re happy. Then once you’ve reached your happy medium, bend some removable aluminum dams (like a c channel) that you can clip on your radiators just to block some airflow. We have to do that here with our oil coolers on some of the experimentals to bring the temps up in the winter. Then in the summer we remove them to allow the engines run a little cooler. It’s cheap, easy, and affective, without producing points of potential failure in the system. I do like your idea of a split system to help each bank. You could also consider installing a in-line thermostat in your coolant system. You can get a thermostat like mine in either 180f (82c) or 200f (94c) that will restrict the flow down then maintain temp. I would rather dam up my radiators but those are options I see. It would at least get things constant and in the meantime if you wanted to design some baffling to regulate your cooling system, you could still fly happily while improving your system
N7777X
Tailwheel
Rotax 912
3 blade Warp Drive
