For the AN386-2-12 taper pin you use a #2 taper reamer to finish the hole.
I have the reamer. Wow! $95.
Do you have any suggestions on how to drill the hole?
What drill size bits would you drill the hole with before using the number 2 reamer?
I saw a good article written by Eric Seber on the #1 taper reamer.
http://www.sonexfoundation.com/uploads/ ... lation.pdfHe "started with a #40 steel bit, updrilled to a #30, and updrilled once more to a #11 hole size. The #11 bit is just slightly smaller than the small end of the taper reamer. I then inserted the reamer and opened up the hole making sure to make several light passes so not to oversize the hole."
What would the equivalent be for the #2 taper reamer?
Rich
