by pappas » Mon Sep 27, 2021 6:26 pm
Well, I finished replacing the heads on my turbo. Trashed the MOFOCO's that came with the 2015 engine and replaced them with the EMPI's that Sonex is now supplying. Also, a new #3 piston, new rings on all pistons, and 4 freshly honed original cylinders.
We match weighted the pistons and wrist pins, ported the heads, and sealed all of the bolts and studs that are through-drilled into the crankcase. I decided to go with Aeroshell 100 for the first 5 hours and will switch to Aeroshell 100 Plus after the rings seat. The aeroshell 100 Plus has the additives already in the oil that Aeroshell put in to do what Camguard does.
3 hours of flight later and I can say that, for the first time, I can climb out at 85-90 mph without any CHT exceeding 365 degrees. (Let alone the 425 deg I was used to seeing in #3). Full rich on climb-out gave me EGT's in the 1175-1240f range. (Likely too rich, but that is ok for the first 5 hours). My oil pressure is up 8-10 PSI, I think that is from the Aeroshell. Way better compression and the acceleration on the take-off roll is noticeably stronger.
I still have a single, lonely, #1 exhaust pushrod tube seal dripping, but no leaks from the cylinder studs or cylinder bases. I'll take it!
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
