by n502pd » Thu Jul 01, 2021 2:41 pm
Good afternoon! Antennas, radios, placements are right in my cone of experience! I have been a ham operator since I was 13, now 76! I have built lots of antennas and placed them to work as well as possible.j
So, for maximum "radiation efficency" ( the ability to be heard?) an antenna should be as close to 'free space' as possible, that is, nothing conductive nearby. laying the antenna down on the glare shield, as you said is improper, because of ground plane as you said, but also that metal next to the antenna detunes it away from its resonant frequency, making the antenna way way less effective for being 'heard'. The best placement for any antenna, at any frequency, is to be as far as possible away from conducting surfaces that are not being utilized as a ground plane. Inside the cockpit, IMHO, is no-no, because of nearby conductors, including the passengers shoulder, detunning the antenna, and partially absorbing energy fron the signal (dont stand infront or near an active radar antenna...it will heat you up from the inside microwave oven style). So, all this said, IMHO, and experience, is to mount the antenna near the aft end of the fuse. I mounted my 121.5 antenna roughly 1/4 to 1/3 the distance from the vert stab-fuse joint, which can protect the radiation ability in case of a flip over. Some have com antennas on the belly, and have trouble with comms while on the ground. the signal isnt going far enouge because of proximity to the partial conductiveness of the runway, earth, concrete,etc.
'The 406 mhz antennas have a matching coil in their base to allow reasonable radiation efficency at both 121.5 and 406 mhz, and that is why they cant be bent over and be expected to function per specs. Further, 406 mhz radiation is more easily interfeered with by nearby objects because of higher absorbsion.
INHO, all that being said, the best place in the aft 1/4...1/3 of the fuse, as long as it is as far away as possible to the com antenna, which is another good absorber of energy.
I know I talk too much! But, beside aviation, radio/electronics has been in my blood for a very long time! Hope I have not confused anyone too much!
And, thanks for your recent conversations on your flying! Keep them up!
Joe
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
