rtro461 wrote:I have the same issue. I have the Nikasil cylinders in a still yet to be assembled Aerovee 2.1 I picked up for my Sonex build. The engine build is not started so I am just watching what is said about Nikasils.
Is this a flight safety problem or a maintenance problem? Has any Nikasil equipped engine stopped while running in flight or on the ground? Or is the issue that the head becomes difficult or impossible to remove after a number of hours? Is this a problem with all Nikasils or just a few?
I had the Nikasil cylinders installed in the AeroVee in my Xenos. I had the same issues the previous posters described. First, when you retorque the heads you will notice that you'll need to tighten the nuts an excessive amount. That is because the cylinders are deforming where they are in contact with the heads. It will be difficult to keep your valves properly adjusted.
After some number of hours, 40? 50? 60? who knows, the cylinders will have deformed enough that they will be difficult or impossible to remove from the heads.
Does it affect all the Nikasil cylinders? I honestly don't know for sure, but I'd bet the answer is yes. I know there are builders that have used the Nikasil cylinders for hundreds of hours. Ask them: have they ever removed the heads? Also ask yourself: why doesn't Sonex sell them any longer?
It's not a flight safety issue IMO. They cylinders won't explode, it'll just be next to impossible to keep the valves properly adjusted.
You'll have enough to keep yourself busy during the 40 hour flight test period. I'd recommend that you save yourself aggravation by spending a few bucks now and buying replacement cylinders.
