fastj22 wrote:I screwed up my first canopy by tightening the bow screws too much. It looked scalloped and I had several cracks from the stress. My second canopy came out great.
First off, don't tap the holes in the bows, just drill through them. Then use machine screws (I think #6) with self locking nuts to secure them. Buy an assortment of lengths. And the counter sunk washers they specify. And a bunch of regular thin washers.
That's essentially what I plan to do. I guess my question was more about the process of transferring the holes from the canopy material to the frames. I assume I locate and drill all the holes in the canopy material first, but then do I locate a couple of hole locations on the bows, drill them and set the screws, mark another couple of holes, remove all the fasteners, drill and clean the second set of holes, install the second set of screws, mark the third set of holes, etc, etc.
I guess my point/question is: I'm afraid if I transfer all the canopy hole locations at once to the frames, that when I go to fasten the canopy I'm going to find that with each fastener I install, the adjacent canopy/frame holes are going to be more and more misaligned due to the canopy moving (squishing out sideways for lack of a better description), to the point that working from one part of the frame to the other, I'll find the final holes are something like a quarter inch out of aliment.
Am I making sense?
Mike
