by lakespookie » Wed May 26, 2021 7:54 pm
I have to wait to get home to look over some video of when i did this but i am pretty sure i clecoed the rest of the skin before i got to the clip, As far as the damaged holes you might be able to oversize the rivets but it would depend on edge clearance.
As far as the process for attaching the skin start on one of the long edges either top or bottom, then work your way length wise to cleco the next set etc, i am assuming you drilled those rib holes with the skin clecoed in this manner.
Dont worry to much about the radius and use the length of the edge from the far side and you can mess around with the folding that edge at the end the last row of clecos seemed like the hardest for me.
