by sonex1566 » Tue Apr 27, 2021 6:18 am
Hi Paul,
Not at the moment, but think of what the fitting looks like at the front of the Bing carby and the AeroInjector, well I just made a double ended piece of tube 2" long to allow for 1/2" of overlap with the rubber insulator as an experiment. It worked a treat, but like I said I am a bit nervous about it icing up, plus the fact that the injector is now held on by two rubber insulators only which is a little bit dodgy. So version 2.0 will be the same principle as the standard adaptor fitted to the plenum chamber but increasing the distance of the AeroInjector from the plenum chamber by an inch. I reckon that Jabiru make theirs by machining it from a piece of solid using their fancy CNC machines. My machining is based on a Harbour Freight type lathe and Mill and me twirling the knobs in the right direction. I was planning on machining the tube and getting it welded onto a flat piece of plate by someone better at welding aluminium than me. I'll keep you posted, I'm hoping that I am on a winner with this.
Richard
Scratch build Sonex
Std gear, dual control
Jabiru 3300, Sensenich prop
19-8776
1st Flight 25th June 2019. 170 hrs so far.....
http://www.sonex1566.com
