Panel Images
Panel designs, construction methods, and pictures
Re: Panel Images
Postby Darick » Thu Feb 16, 2017 10:41 am
Glenn,Thanks for the heads up. Right now it's velcroed in place.
Bryan, ooo, that pesky engine paint! To be finished...cowl, windscreen, canopy, attach tail and flight controls. Doesn't sound like much buttttt.... :roll:
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Panel Images
Postby vwglenn » Thu Feb 16, 2017 10:48 am
Also plan to use a pen or a stylus for it. I'm an average dude and trying to manipulate that thing with my fingers makes me feel like King Kong trying to thread a needle.
Glenn
Sonex #600
N889AP
vwglenn
Re: Panel Images
Postby WannaFly » Sun Dec 08, 2019 9:31 pm
I'm soooo happy with my very clean panel.. Rights side for my big Ipad. Contaced a label guy on ebay then drew of the lables--$20 for all!!
Onex Turbo Aerovee first flight June 3 2019!!
RV6 in progress
Rans S14
Vector 627
100 hours 172
last flew 9/28/2000
WannaFly
Re: Panel Images
Postby Bryan Cotton » Wed Apr 28, 2021 11:19 am
Adding my finished panel to this thread:
My compass is mounted on the windshield bow.
Re: Panel Images
Postby BRS » Thu Apr 29, 2021 10:32 am
Here is my (almost) complete panel. All that is missing is ignition and starter switches, as I'm still waiting on the RevMaster to arrive. The goal was to keep it simple and clean. The MX1 controls the v16 radio and the TT22 transponder which are mounted under the seat. The iPad is running FlyQ and shows all the ADSB-in stuff as does the MX1. The ADSB-in comes from a Stratux which is also hardwired to the MX1. The Stratux has 3 antennas, GPS is center glare shield then two 'rubber duckies' on each outside of the glare shield. Picks up traffic easily while still in the hangar.
Engine switches will go below the USB charger and behind the iPad.
The panel is cut from heavy .080 6061 and is in three sections. I can easily remove the center section (5 screws) with the MX1 to gain access to the wiring on both the right and left sides.
[Be sure to click on the image to see all of it]
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: Panel Images
Postby Rofomoto » Thu Apr 29, 2021 5:30 pm
Image[/url]
1735
Longassproject
Rofomoto
Re: Panel Images
Postby Sonex1517 » Thu Apr 29, 2021 10:30 pm
Here’s my panel and very incomplete interior.
Flightline FL760 radio, GRT Mini, Garmin GTX-327, and a uAvionix Echo under the seats. Upper left is my LRI and a TinyTach so I can see the lift and power in the pattern without looking down.
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: Panel Images
Postby NWade » Sat May 01, 2021 5:02 pm
I just realized I never posted a pic of my completed panel. It came out pretty clean, if I do say so myself!
Now I just need to fix the expensive g*dd%mn air compressor that broke down just as I got into painting my bird, so I can finish her up and get the first flight in this summer!
--Noel
Sonex #1339
NWade
Re: Panel Images
Postby BRS » Sat May 01, 2021 9:34 pm
NWade wrote:I just realized I never posted a pic of my completed panel. It came out pretty clean, if I do say so myself!
Do you have a controllable pitch prop or are you using blue for mixture?
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: Panel Images
Postby NWade » Sat May 01, 2021 11:12 pm
Its mixture. Yeah, I know. its the one "non-standard" thing I've really done with the controls; but I got it on sale from ACS and its a nice push-button Vernier control so I can really fine-tune the fuel flow in cruise. And its not like someone's going to jump in the aircraft and _not_ figure out right quick that's the mixture control. :-)
--Noel
NWade
Return to Panel
