LarryEWaiex121 wrote:If the plane isn't manufactured according to the plans, i.e. your own brand of engine, modified fuel tanks and pumps, non conforming airframe modification, then the unit doesn't qualify as a Sonex in terms of insurance. It's a custom and should be treated as such.
FWIW, I tried to honor the factory request to not use their name on my build. It's actually registered as a "Myunn" but the registration still shows the name of the kit supplier. But does this mean that everyone that added wing tanks now has to rename their plane? 8-)
LarryEWaiex121 wrote:The simple fact is too many unproven mods are being done, with low experience pilots doing their own test flying. Things go wrong and they are not qualified to handle the results.
This is true for every modified kit plane regardless of the supplier so this point would not specifically apply to our planes.
LarryEWaiex121 wrote:Vans has vastly more airframes in the air but casual observation tells me that they have a proportionally lower rate of engine/fuel related failure than Sonex airframes. Even if the actual difference is small, the perception is hugely NOT if favor of the Sonex. I've heard this many times from my flying friends. The old saying is, "perception is reality". I know locally 4 Vans owners that looked at the Sonex and passed on it because they felt the recommended engine packages were not acceptable to them. Out West, for many the Aero-vee is a complete non starter do to density altitude most of the year.
To my knowledge there isn't a single Van's aircraft flying with a converted VW engine (I realize the VW doesn't make enough power) but the point is that most Van's builders are using aircraft engines and not auto conversion engines. Still, some are using Subaru engines and such.
But your point is clear even if others do not realize the impact of it. Look and see the total number of threads all over the web about the overheating of the VW conversions (not just on these airframes) and the extreme difficulty of setting up the factory supplied slide carb. The little VW engines work well but there is a limit to how much power it can produce and how much heat it can stand. Personally I believe the 80 HP VW engine is very taxed in the hotter southern states. Some have mentioned moving the sensors to get a better CHT reading but that's not addressing the problem.
FWIW (again) my insurance on my 120 HP tail wheel airplane had a very small increase over last year (~$20) and my overall cost is under a grand for a newbie tail wheel pilot, 25K in hull, and the standard liability. I've read how WW worked with insurance companies to get approval for his conversions on experimental aircraft. When I applied for my insurance policy I was very upfront about the type of engine I had, the factory stance on the FWF weight limit, and the fact that I had increased the gross weight over the factory recommended limit by ~8%. They thanked me for my candor and noted these things on my policy.
Dunno if this helps ...
Dale
