by Kai » Thu Apr 22, 2021 4:15 pm
In engineering, there is always a better way........
Why Rotax in the first place could not design their 900-series with a vertical flange mount for the isolators to sit horizontally, thus always loading them in compression/tension like Camit, Jab, UL, VW, LyCon, D-Motor, etc etc have done for ages, is a mystery. Of course Rotax has their bolt-on ring mount solving all issues, but it is heavy and shockingly expensive.
And, as many have discovered, once the ring mount is in place the issue with the water pump inlet elbow has to be dealt with, as the ring mount effectively blocks any possibility to hook up a hose. It forces the builder/installer to design and weld up an alumimium inlet elbow with a 35mm long neck.
So the question remains- which evil to choose? The engine has to be cooled and overloading the isolators must be avoided.
Preferences, preferences.........
Thanks
Kai
