by CaseyCooper » Fri Apr 02, 2021 1:37 pm
I agree with Jeff. A good weight and balance is key. Mark and I have been working together on compiling data/information for Rotax powered Sonex’s, every build will be different of course meaning more/different data. But, more people flying them, means more results. Which will benefit everyone in the long run.
I ran a weight and balance with Mark just to be certain of figures and this is what we came up with. I’m at the forward limit for my weight and full fuel, but have no way of going further forward. As fuel burns off, with passengers baggage etc., it still remains in range quite well.
In my opinion, weight and balances don’t always match up on paper vs real world. Rigging comes into play (flaps up or down slightly for example will move your center of lift forward or aft), and of course slight irregularities in measurements, etc. It happens!
One of my intentions of running a 64” Warp Drive, which is solid carbon fiber, extremely durable, but consequently heavy, was to get my cg forward. Being a 3 blade it puts more weight in the front, which was a benefit of offsetting the lighter power plant weight. Also I’m running a 2” spacer the same diameter as the prop flange.
I’ve been attempting to upload a picture of the weight and balance we compiled but the website isn’t letting me. So I’ll try again later!
But for now here are some basic figures I have;
Empty weight: 666 lbs.
Empty cg: 16.85%
Max Forward with 180 lbs pilot and 96 lbs fuel: 20.31%
Max Aft with 180 lbs pilot 170 lbs passenger 38 lbs baggage 6 lbs fuel: 31.21%
Full Gross with 180 lbs pilot 170 lbs passenger 38 lbs baggage 96 lbs fuel: 27.61%
Obviously these percentages can vary given different weights and their location, and also different aircraft with different configurations.
N7777X
Tailwheel
Rotax 912
3 blade Warp Drive
