by MichaelFarley56 » Thu Sep 05, 2013 6:37 am
I don't think there really is one set length of pipe that you need to cut to, but from my own experience I would recommend that you cut the pipes long enough that they stick several 4"-6" below the bottom of the cowling/fuselage line. I cut mine so I only see around 2"-3" of pipe and every once in a while, when I'm at a really high angle of attack, I can smell a little exhaust entering the cabin. Not enough to worry about and it goes away as soon as i add power, but still enough to make me wish I had left my pipes a little longer.
While we're on the subject, I also recommend you head to your nearest Jegs and get automotive exhaust pipe wrap and wrap your whole exhaust system. I've done this and it's amazing how much cooler your cowling is after the exhaust is wrapped. It really goes a long way in keeping everything in the cowling much cooler, including fuel lines which may help reduce or eliminate "burping" from the engine.
Waiex #0056 - N569KM
Jabiru 3300A #1706
