Onex107 wrote:You call it flutter and if it truly is flutter it's very serious. Your nose wheel steering should be spring loaded like my Onex. I highly doubt that the nose wheel pant would flutter unless there is a lot of play in the steering. I have seen 160 mph on mine with no vibration. Tires spinning fast enough to be out of balance? Doesn't happen. Flutter is a serious problem and if it's a control surface it can be fatal. Zenith had four or five fatalities attributed to unbalanced ailerons and they made a major engineering change to prevent it. Flutter should not happen on a Sonex.
Users browsing this forum: Capt T and 13 guests
