broken rocker arm spacer
Postby Johns » Wed Mar 24, 2021 6:55 pm
Went to gap valves and found a spacer in two pieces. It is a spring (tension) spacer because it is not flat. Can not find one on-line anywhere. If any one knows where I can find these please let me know. If you have Tom Wilsons VW book it looks exactly like the one on page 112 at the top of the page with the clips on the ends.
Thanks, John
Johns
Re: broken rocker arm spacer
Postby AlexZ » Thu Mar 25, 2021 3:27 am
Alex
Flying:
Sonex Legacy TD PH-AWX Aerovee https://www.facebook.com/SonexPHAWX/
RV-7A PH-PWP
Building:
Piel CP1320 https://eaabuilderslog.org/?s=CP1320
AlexZ
Postby rizzz » Thu Mar 25, 2021 8:23 am
Johns wrote:Went to gap valves and found a spacer in two pieces. It is a spring (tension) spacer because it is not flat. Can not find one on-line anywhere. If any one knows where I can find these please let me know. If you have Tom Wilsons VW book it looks exactly like the one on page 112 at the top of the page with the clips on the ends.
Thanks, John
They’re called “wavy washers” and they’re only found on the stock VW rocker assembly.
These have been known to break when used on anything else than the low power original 1300-1400cc engines, which is why the solid rocker shafts are commonly used now.
What engine do you have? If indeed you have the stock rocker assembly, I strongly suggest upgrading to solid rocker shafts. They don’t cost very much at all.
If those wavy washers were installed on a solid rocker shaft, you will need to replace them with the proper shims.
Postby Johns » Thu Mar 25, 2021 9:48 am
Thanks guys,. I did not build this motor but according to the log book they are porsche 914 heads on a 2300cc motor. I will check to see if they are the solid shafts and go from there. Will replace all with the proper shims.
John
Johns
Postby rizzz » Thu Mar 25, 2021 8:43 pm
Johns wrote:Thanks guys,. I did not build this motor but according to the log book they are porsche 914 heads on a 2300cc motor. I will check to see if they are the solid shafts and go from there. Will replace all with the proper shims.
John
That implies you have a type 4 VW conversion which is different from the type 1 VW's that are commonly used as the basis for engines like the AeroVee, RevMaster, GP & Hummel.
Type 4's are quite a different animal from the type 1's and also very rare.
I don't know much about the rocker assembly on the Type 4 and I doubt many people on this forum will.
Do you have a picture of the engine?
If it is a type 4, forget what I said in my previous post as it might not be valid in this case.
I suggest you consult the people on one of the VW forums like thesamba.com.
Postby Johns » Fri Mar 26, 2021 3:36 pm
Rizzz, thanks for your input. All items were purchased at great plains aircraft so I'm pretty sure it's just a built up type1.
John
Johns
Postby kmacht » Fri Mar 26, 2021 5:27 pm
Porsche 914 heads are almost exclusive to a type 4 motor. I don’t think they will even fit on a type 1 but could be wrong. Great Plains sold both type 1 and type 4 conversions for many years. You may want to give them a call to figure out exactly what you have so you get the correct parts.
#554
Postby Area 51% » Fri Mar 26, 2021 5:55 pm
Type 1 heads have intake ports that almost touch one another. The Type 4 heads have somewhere around a 2 inch gap between them.
Users browsing this forum: petep and 49 guests
