The AVC1 works a little differently than many regulators for permanent magnet type alternators and as a result, the alternator wire no longer provides a reliable tach signal. If you use the AVC1, you will need to come up with another source for a tach signal.
For a tach pickup, I’m familiar with what is being used with Corvair conversions because I’m using a Corvair in my project. Here is a link to the sensor sold at flycorvair.net. https://flycorvair.net/product/3411-tach-pick-up/
If Garmin can handle lots of pulses per revolution, then you can point the pick-up at the ring gear teeth. If you have to keep it to a smaller number of pulses per revolution, then the Corvair method is to put two bolts in the ring gear and have the tach-pick-up count the bolt heads resulting in 2 pulses per revolution.
Users browsing this forum: autopro, Dave Wolfe, Google Adsense [Bot] and 77 guests
