by CaseyCooper » Wed Feb 17, 2021 2:20 am
As far as CG calculations go, and feel of the aircraft in the real world instead of on paper, my Sonex is very well balanced. My cg calculations full forward, and aft, fall right in FAA standards, and within Sonex limits. Solo with full fuel I’m actually just aft of the forward limit by .20”. In flight when solo and full fuel I have to barely apply nose up trim to maintain straight and level flight. I weigh 180 lbs.
I know you might think, well how can that be? A lighter power plant all the way up there and still on the edge of the forward limit?
It really pretty simple. I’m running one of the heavier props you can get, and a three blade at that. As well as a 2” billet spacer. So it may be a lighter power plant, but my moment arm with a considerable amount of weight compared to a Sensenich like most people run on Aerovees and Jabirus, makes a difference. It’s an easy way to move your CG without just adding weight to the front. In the pre-flight stages I was actually considering using a 4 blade prop, with shorter blades, to move my cg even further forward. But with some calculations prior to choosing my propeller I found out that wouldn’t be necessary.
In my opinion spacers are nothing to be afraid of. People use them for good reason and they allow for assistance in these instances where we might need a little more clearance or help elsewhere.
Brett,
I wouldn’t worry about issues during spins or wing overs with your Rotax. As long as you are coordinated and keep positive G’s you won’t have an issue. It’s only a problem if you’re negative for more than a few seconds which is the same with most aircraft without an inverted fuel system. I’ve seen plenty of people do spins, I’ve seen 7 full rotations, and not have an issue. The 3300’s use just a larger version of the 912’s and they perform just fine as well. Although I do recommend operating with an electronic fuel pump as back up, or ON prior to any “aerobatic” maneuvers.
Rotax’s are pretty easy when you get down to the peas and carrots of them. The carbs are nothing to be afraid of, as long as you know how to properly tune them, or have someone who does, they’re wonderful. As most of us know, in the experimental category we can do whatever we want with our aircraft (almost) which means we can run stuff indefinitely if we so choose. But replacing the mechanical pump every 5 years per Rotax specifications will keep things happy.
N7777X
Tailwheel
Rotax 912
3 blade Warp Drive
