rick9mjn wrote:the question from ;Art,,,,Sonex taildragger #95,,,Jabiru 3300 #261
is ;I had looked for a pinhole coupling ??????
a may be answer to the question is """Wicks aircraft supply""" part #ea22r-o,,,,,,,restrictor fitting 1/8npt ,,orifice size .040
....good day / rick
GordonTurner wrote:Just looking at the McMaster chart for water at 40psi...
.010 gives .016gpm which is 62 minutes to flow one gallon.
.029 gives you only 8 minutes.
I’m not sure at what point during the leak scenario you would likely be able to notice and conclude you had a leak, but if the .010 orifice works it sure gives you a better chance to get on the ground.
GraemeSmith wrote:My high pressure pulsing seems to be temperature related. Especially on cold days - even when the oil has got good and warm - it still sometimes pulses. So I thought I would start with the easy: Shield the pressure sender from a cold air blast.
