Bing Air Questions
Bing Air Questions
Postby racaldwell » Sat Feb 06, 2021 6:53 pm
I am connecting up the air system to the Bing Carb. I am using the stock Jabiru air filter box with integral carb heat diverter.
The manual says the air supply to the filtered air box needs to be connected to outside air, not from inside the cowling. I thought I have read that connecting to outside air could create uneven fuel/air distribution.
Where should the air supply be connected?
It certainly would be easiest to leave as is open to the air inside the cowling.
I have a manifold pressure sensor built into the GRT R66 EIS. I would like to connect it just because it is there. Is there an easy solution to connect to the induction system?
Rick Caldwell
Xenos 0057
Air Filter Mounted Sm.jpg (171.11 KiB) Viewed 1773 times
Air Inlet Duct Layup Sm.jpg (167.76 KiB) Viewed 1773 times
racaldwell
Re: Bing Air Questions
Postby sonex892. » Sun Feb 07, 2021 6:20 pm
Hi Rick. This is how I connected the airbox to outside air. The NACA duct is fixed to the cowl and just plugs into the airbox fitting as the cowl goes on. I always meant to replace this polyester glass prototype, but 10 years and 500hrs later its still there and working.
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby racaldwell » Sun Feb 07, 2021 9:34 pm
Thanks Steve, I'll look at my options for getting outside air. Maybe from the inlet air to the oil cooler?
I Finished the duct between the carb and filter housing today.
Air Duct Completed Sm.jpg (180 KiB) Viewed 1686 times
Rick Caldwell
Xenos 0057
racaldwell
Return to Jabiru
