Revmaster R2300 on the Sonex?
Re: Revmaster R2300 on the Sonex?
Postby fastj22 » Tue Nov 12, 2013 12:57 pm
Has anyone considered putting a Corvair on the Onex? I know it will probably push it out of LSA compliance due to speed, but that could be handled like the Carbon Cub did.
Postby MichaelFarley56 » Tue Nov 12, 2013 4:09 pm
I'm certainly no expert, but I would think a Corvair in a Onex may be a little too heavy for that airframe. You're talking about adding another 30-40 lbs right on the nose.
On the other hand, it sure would be fast!! :mrgreen:
Waiex #0056 - N569KM (sold)
Onex #245
Postby fastj22 » Tue Nov 12, 2013 5:21 pm
I'm really starting to think the Onex might be my next project unless the Panther really progresses and starts selling complete kits.
I think the Onex has a bit of a tail heavy issue anyways so going lighter than an Aerovee brings issues.
Look at the Jab2200 one. The builder had to extend the engine mount forward to get the CG right. It created a really long nose on it.
The D-Motor would have the same problem.
But I need more than 80HP up here.
The turbo Aerovee will do it if it becomes available, but that comes in close to the weight of the Viking or Corvair.
Just thinking out of the box, but one way to deal with the heavier engine would be to build a fuel tank behind the seat, or wet wing, and use a header tank. Eliminate the need for the fuel fill through the windshield too.
Postby daleandee » Tue Nov 12, 2013 11:48 pm
daleandee
Postby fastj22 » Wed Nov 13, 2013 10:35 am
I got to sit in the Panther at Airventure. Like you say, very innovative and stylish. Got to meet Dan and Tony Spicer too. Even got a folding wing demo.
My only concern with them is they are a startup company with a monumental task ahead of them. I really hope they are able to pull it off. But I would hate to be caught with a partially built kit and no support because of something out of my control. Maybe by the time I'm ready to pull the trigger they will have full kits out.
Right now, I'm leaning towards the Onex with hopes the turbo will be ready when I need it.
Postby radfordc » Wed Nov 13, 2013 11:03 pm
If you set the GW at the recommended 1100 lbs your RoC will be very satisfactory. At 1150 my Sonex climbs about like a fully loaded C-150. At 1200 things start to get a bit sticky.
radfordc
Postby Chris9183 » Thu Nov 14, 2013 8:18 am
radfordc wrote:If you set the GW at the recommended 1100 lbs your RoC will be very satisfactory. At 1150 my Sonex climbs about like a fully loaded C-150. At 1200 things start to get a bit sticky.
What engine you using?
Chris9183
Postby radfordc » Thu Nov 14, 2013 9:26 am
Aerovee
radfordc
Postby radfordc » Thu Nov 14, 2013 6:18 pm
Jeremy hit on some rate of climb numbers in his webinar last night. He thinks 400-500 fpm is a good average for the Sonex. That fits my observations too. On a good cool day you can do better than 500 fpm.
radfordc
Postby MichaelFarley56 » Thu Nov 14, 2013 8:26 pm
That's what I was getting too. Waiex, AeroVee, 950 lbs (just me and full fuel) on a cool day averages around 900 feet per minute. At gross of 1100 lbs that's 400-500 feet per minute, and I still find the most interesting part is how much warmer the engine runs at higher weights. Once leveled off in cruise there's minimal difference in airspeed and engine temps.
Onex #245
Users browsing this forum: Google [Bot] and 77 guests
