by CaseyCooper » Mon Jan 25, 2021 12:16 pm
Kai,
Thank you very much. I appreciate that. Any suggestions are good suggestions! So I’ll take any criticism I can get!
The Rotax definitely has its own personality. The gear reduction and compression make for an interesting start up and shut down compared to something like a lycoming or continental. That’s definitely something to take into consideration.
Maybe I will try and make some new mounts and move them further apart, but unfortunately, I don’t have a ton of room to work with but every bit helps. It’s only in the “just in case” realm right now so fortunately I have time to prototype.
There is definitely concerns when installing your oil system. However the banjo bolt/sump is not under suction, it’s under pressure, from the oil pulled into the pump at the front of the engine and circulated through. If there was a leak, it wouldn’t starve it, unless the it was so substantial the oil can ran out! Which is a scary thought in itself. Always watch those oil pressures! But I agree on the clamp. This one is, like you say, barely big enough to where I have a small tail coming out. There is definitely an art when using a standard hose clamp knowing when enough is enough. Too little, leaks, too much, curled rubber coming out of the clamp.
Thank you very much for your insight, it’s always good to have someone to bounce around ideas with!
N7777X
Tailwheel
Rotax 912
3 blade Warp Drive
