DuncanK wrote:I've now flown my Sonex with a UL350i. My oil cooler is mounted on the center-line below the prop, angled (roughly) with the cowl and exposed to ram air. This required quite a lot of modification to the cowl but one advantage is short and simple oil lines to and from the cooler (its not a UL cooler).
I previously stated that I reduced the area and relocated the Sonex cowl inlets. Also, in addition to the standard Sonex side exits, I added two louver exits on the underside of the cowl. The resulting exit to inlet area ratio is about 3.
Oil Temps:
The oil temperatures in flight (based on a few spring time flights) are good. On the ground at full power, the oilT rises quite quickly and the oilT limit is reached after a couple of minutes or so. Taxing, run-up checks, and waiting a few minutes for takeoff does not cause an oilT problem.
CHTs:
I have CHTs on my left and right rear cylinders. On the ground these climb slowly (or quickly at full power) but a left to right difference is evident. After a longish taxi and run-up, the difference left to right can approach 100 degrees F (the higher temperature is still below the CHT limit). Good news, once airborne the temperature difference quickly decreases and the left and right are equal after a few minutes.
In summary, I am pleased with the results from my oil cooler location and the cowl cooling mods.
