WaiexN143NM wrote:hi all,
we had a very small leak in one of our legacy molded in tank fittings. we used a glue from locktite, called a plastics bonding system. has a primer stick, and tube of glue. looks exactly like a super glue tube. red/blue package. no part number, but bar code on back is 7934082565. for all plastics , poly e and poly p. our fitting on the lower rt sump in tank on verticle side started to barely drip. we drained tank, let sit for a few days. took out brass plug. cleaned outside with scotch brite, wiped w acetone, primer stick tank and fiber washer. glue applied on tank, fiber washer metal washer screw. tightened up. never leaked since. locktite sells this. mfgr is henkel corp, rocky hill ct. this fitting was never used, go figure. avbl from home depot, lowes, ace hardware, true value.
WaiexN143NM
After flying my Sonex for 15 years I tempted fate one too many times when I installed a red cube fuel sender unit just downstream of the tank shutoff valve. Oh no, the main fuel tank outlet fitting began to leak around its perimeter after being disturbed by this work. So I tried something like what Michael describes above in his message. I made a 1 1/2" o.d. washer out of a potato salad container lid. It is made from polypropylene (#5 plastic) and was glued to the tank using the Loctite product mentioned in Michael's message. Although probably not necessary, I used J-B Weld around the pipe where it went through the pp washer (with its paper label intact)to help stabilize the pipe connection to the washer and the tank.
It's now been about 6 months and about 50 hours flying time and so far no return of the leak. So thank you Michael for pointing out that it might not always be necessary to go to the trouble of installing an oops fitting for a relatively small leak.
Thinking there would be a need for more than one package of the Loctite product, I bought three online and used less than one. So if anyone has a need for this stuff, I'd be happy to mail it to to you before the shelf life runs out, if there is one.
Art,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,Jabiru 3300 #261
