by lpaaruule » Sun Jan 10, 2021 12:38 pm
I send the below email to GRT Avionics a little while ago, but thought I'd also post it here in case any of you have experienced a similar issue, or have any ideas.
Hello. While flying I occasionally have GPS signal lose for a few second. Yesterday, I lost GPS signal for for a couple minutes during flight following. The track has me turning the wrong way until I started using the magnetic heading.
I’m not sure if the interference is coming from inside the plane or outside. I was near a military base, but I’ve had it happen other places as well.
What’s even more confusing is that I also occasionally lose GPS signal on my cell phone at he same time. My phone is using an app that communicates wifi with a Stratux. I don’t know if the app uses the Stratux GPS position of it’s own. The Stratux is also serially connected to my SportEX for ADS-B info, which works great.
I fly a Sonex, and I have two GPS antennas on the glare shield. My comm antennas are on the bottom of the plane. However, the GPS antennas are coiled up under the instrument panel, and are close to the comm coax.
I’m considering rerouting the GPS cable locations, but right now I’m just guessing what the problem could be. I’m also considering removing the GPS antenna that goes directly to the EFIS, and just using the one for the SafeFly 2020.
Any suggestions would be appreciated.
