Area 51% wrote:Ryan, Where do you have your CHT probes mounted? My engine seems to be running hotter than expected at 25hrs, but I'm wondering if it might only SEEM to be running warm because my probes are under the spark plugs and not screwed to the cooling fins as suggested by Sonex.
To test that theory, I've purchased another probe that I intend to attach to the fins to compare any temperature differential between the two locations.
I've already enlarged the cooling exit twice (3/4in each time) with no noticeable change in head temps.
Rynoth wrote:My current and highly experimental opinion is that exit area/extraction is crucial for cooling. Whether side-vents or bottom-vents are better for airflow I do not know. I have a vertically split cowling with the bottom vent, and I may soon add side vents to increase cooling.
How the cowling is split is irrelevant for cooling, what matters is the airflow (intake area, exit area, and baffling). I'd rather have discharge air on the less-sightly bottom of my fuselage then on the sides, but I'm willing to play with other options if it means better cooling.
