vigilant104 wrote:Chris,
The Revmaster R2300 has been on the scene for a while now, it is possible there are some fitted to a Sonex and maybe someone will chime in. I own an Aerovee-powered Sonex and have flown it at 1150 lbs (the MTOW at which it is registered). I would not say it "struggles pretty hard with a bad climb rate", though most of my flying is from fields below 2000' MSL and at OATs below 90 deg F. At higher density altitudes I'm sure the climb rate decreases.
The in-flight adjustable prop has some issues. The plane wouldn't qualify as an LSA anymore, and even if that doesn't affect you (now), it might make your plane less attractive to other buyers in the future. Weight, cost, and added complexity are other factors. I don't know about the IVOPROP in particular.
My take: As you only plan to fly "heavy" infrequently, I wouldn't get too hung up on the climb rate situation unless you'll be operating at high DA fields or need to meet a challenging climb gradient for other reasons (extensive vertical terrain, etc). If I've got the plane loaded up and headed somewhere, and if I can climb out of the field safely, I'm not concerned if it takes me a couple more minutes to get to my cruising altitude, as I'm already headed in the right direction and covering ground the entire time. But, I'm sure everyone has their own opinion on this.
daleandee wrote:Might I suggest a nice Corvair conversion? Gobs of power, cooling is not an issue, can build it yourself or buy it built, and gross weight is not a problem. My gross is 1250 and she handles that very well as others have noted. Took the wife with me yesterday to a Corvair College to show my aircraft to other Sonex/Waiex builders that are using the Corvair engine.
Your decision but I thought I would remind you of the best option currently available for the Sonex. 8~)
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
51.2 hours / Status - Flying
http://www.youtube.com/channel/UC49h6Qijc17_Ebfz0CbRFtg
http://websites.expercraft.com/daleandee/
http://groups.yahoo.com/group/carolinasportflyers/
Users browsing this forum: Google [Bot] and 92 guests
