by pfhoeycfi » Sun Dec 27, 2020 10:38 am
The 1/4" NPT thermostat fitting screws into a gauge tee on the outlet of the turbo bearing block. However the specified American Volt thermostat fitting drives so far into the Summit Racing tee (finger tight) that it may as well be a gate valve. I ordered more tee's from Jegs and elsewhere same issue. Does anyone have a recommendation for both thermostat and AN/NPT/NPT tee that will actually work? The tees, stat or both are poorly cut.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
