MGL EGT SENDER
MGL EGT SENDER
Postby pfhoeycfi » Sun Dec 13, 2020 10:28 am
I do not have the MGL EGT senders yet was wondering if anyone could confirm the probe hole drill size. From what I have seen it might be 1/4". I emailed the MGL rep ...no response.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: MGL EGT SENDER
Postby pilotyoung » Sun Dec 13, 2020 10:42 am
Michigan Avionics took over support for MGL some months ago. Did you e-mail Adam there?
pilotyoung
Re: MGL EGT SENDER
Postby pfhoeycfi » Sun Dec 13, 2020 11:47 am
pilotyoung wrote:Michigan Avionics took over support for MGL some months ago. Did you e-mail Adam there?
I emailed the main contact address at Michigan not him specifically.
Peter Hoey
pfhoeycfi
Re: MGL EGT SENDER
Postby Stevetin » Tue Dec 15, 2020 3:33 pm
I have the MGL EGT thermocouples in my Aerovee engine. I purchased them from Aircraft Spruce (11-07842). The probes are 5mm but the holes in the exhaust pipes are 13/64". Hope this helps.
Steve
Stevetin
Re: MGL EGT SENDER
Postby pfhoeycfi » Tue Dec 15, 2020 4:17 pm
Stevetin wrote:I have the MGL EGT thermocouples in my Aerovee engine. I purchased them from Aircraft Spruce (11-07842). The probes are 5mm but the holes in the exhaust pipes are 13/64". Hope this helps.
Steve
Perfect...
Peter Hoey
pfhoeycfi
