Ed Kollin wrote:I would probably use a 15W-40 diesel oil like Shell Rotella
Don't think I'll try that yet!
BRS wrote:Graeme,
What fuel are you using? As mentioned earlier (about TCP) lead from 100LL likes to settle out of most automotive oils (is that true with the VR1?). I remember running a rotax 914 where lead settling was noticeable. Nice thing for rotax is that the remote oil sump is easy to open up and clean out. In my Lyc (sportsman) I run Phillips XC and 100LL. But in the sonex (still under renovation) I've not yet decided what I'll run in the revmaster. I'm not a fan of ethanol and 'clear' is not much cheaper than 100LL.
Blackstone Labs wrote:The last sample looked uncharacteristically good, with most metals reading at some of their lowest levels on the page. That makes for a tough act to follow because metals can't always read at their lowest levels, otherwise at some point the engine would have to start putting metals back on the parts. So this report looks fine. The wear levels are certainly out of line low compared to what we've generally come to expect from this particular engine. No contamination was found. Looks fine from here.
