Here's some of the work from building the panel. It was really important to me that everything be easy to service, so I made the face of the panel removable. I own a 1953 Piper Tripacer and I have found whatever maintenance is difficult typically gets delayed or ignored. I really want to put a ton of hours on this airplane over a long period of time so I'm doing what I can to make it easy to maintain. I put all the wiring into and out of the panel on disconnects and made the face of the panel removable. In addition, each instrument is relatively easy to remove one at a time.
I designed the panel using Solidworks and had it waterjet cut. The panel is .020" aluminum bonded to an etchable plastic. I plan to (but haven't yet) laser etch all of the text on the panel. If I want to get really fancy down the road, I can also backlight the panel so the etching glows. Given how much work everything has been thus far, I don't think I'm going to do that.
I went with carling rocker switches on the panel because they felt really nice and because they could be custom etched and backlit. They're pretty big for a panel as small as the Onex but I was able to make them fit with out too much hassle. I really like having lit switches, for one it will tell me if I left something on unintentionally and flying at night will be easier also.
I was really intimidated to do the wiring on the airplane but I had some really good and patient mentors at work that showed me everything I needed to know. In the end, I found the wiring work to be very fulfilling and fun. I found that the most restrictive limitation for the Onex panel was not the panel size itself but the room behind the panel. it was hard to find instruments that would fit in such a shallow space. This is what drove me to the Trig radio, it was expensive but I'm happy with it so far. The Trig hardware is super nice and the install is really straight forward. I haven't flown with it yet but I'll report how it works once I have a few hours on it.
- Waterjet cut faceplate and cutout old panel with nutplates
- Rocker switches in rack
- Building up the panel
- Wiring the panel, before cleanup
- Finished panel
