Rynoth wrote:re: the replies so far... the OP is just trying to set his shims (i.e. the case halves aren't mated yet) and the plans do indeed call for an impact wrench to be used. That said, I believe I just snugged it up with a breaker bar, but I don't recall how I secured the crankshaft. It is a bit of a tricky maneuver since the crank is still loose in half of the case, and an impact wrench may help reduce motion of the loose crank.
