by pappas » Sun Oct 11, 2020 4:57 pm
I am flying a Waiex B turbo now with an electric flap actuator which works great and I like it, but my first Sonex was a 3300 powered legacy Waiex. I also needed Popeye strength to pull the flap lever to the last position.
I struggled with it for a few months. Finally, I discovered that the flap problem was not a flap problem...it was a speed control problem, pilot induced. All I needed to do was to fly the plane as the designer intended. Do not even put your hand on the flap lever in an attempt to pull full flaps until the airspeed is just under 70 mph! 73, a struggle, 72, a struggle, 71, a struggle, 70, maybe, 69.....like butter, 65, melted butter, and no pilot induced porpoising from sawing at the control stick.
Simple is good and every good landing is a result of controlling your airspeed from the downwind leg to right in front of your hangar. Be ahead of the airplane and the flap problem disappears.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
