Rivet hole size
Rivet hole size
Postby dbdevkc » Mon Aug 01, 2011 11:42 am
Here is another one I also posted to the sonextalk list. I notice that the ccp-42 rivets are ever so slightly loose in the holes made by the #30 drill bit. Is there a reason we do not drill them with a 1/8 bit instead?
[color=#800000]Kevin Conklin
Building Waiex #169
dbdevkc
Re: Rivet hole size
Postby Andy Walker » Mon Aug 01, 2011 1:22 pm
It's probably just to make aligning holes and inserting rivets easier. I don't know for sure, but it might be possible to have the rivet/hole mating be "too" tight. I could envision that could cause cracking in some circumstances (just speculation of course). Nobody has complained about Sonex joints getting loose, so it's probably unnecessary to re-invent the wheel on this.
As an aside, when I have to drill out a rivet, I use a 1/8" cobalt bit. Cuts through the SS rivets like butter, and even if I drill right through (I try to stop short and pop the head off with a punch) the slight undersize compared to the #30 leaves the hole unmolested. So that could be one advantage of using #30 for your holes.
Andy Walker
Re: Rivet hole size
Postby Bacon8tor » Fri Nov 01, 2013 3:52 pm
I'm just starting my project and want to get this straight. Do we use the #30 (or 1/8 inch) bit for both the CCP 42 and CCP 44 rivets? I assumed the #30 was for the CCP 44's and the #40 for the CCP 42's but the 42's don't fit in the #40 holes even though they are both 3/32 inch diameter. I'm confused.
John Bacon
Henderson, NV
Onex 164 N702JB Reserved
95% done.....
Bacon8tor
Re: Rivet hole size
Postby sonex892 » Fri Nov 01, 2013 4:38 pm
Bacon8tor wrote:I'm just starting my project and want to get this straight. Do we use the #30 (or 1/8 inch) bit for both the CCP 42 and CCP 44 rivets? I assumed the #30 was for the CCP 44's and the #40 for the CCP 42's but the 42's don't fit in the #40 holes even though they are both 3/32 inch diameter. I'm confused.
The only difference between CCP 42, CCP44 and CCP 46 is length. They all use a final hole size of #30.
1/8" is actually slightly smaller than #30
sonex892
Re: Rivet hole size
Postby Bryan Cotton » Fri Nov 01, 2013 4:40 pm
None of our rivets are 3/32. That is just the size of the pilot holes. There is a table of these rivets at A/C Spruce.
http://www.aircraftspruce.com/catalog/h ... nrivet.php
Re: Rivet hole size
Postby Bacon8tor » Fri Nov 01, 2013 4:53 pm
Thanks, guys. I get it now. Didn't mean to hijack your post, Kevin :-)
John Bacon
Henderson, NV
95% done.....
Bacon8tor
Re: Rivet hole size
Postby Sonex825 » Tue Nov 12, 2013 11:28 pm
The CCP/CCC/AAP-3X rivets are 3/32
Sonex825
Re: Rivet hole size
Postby rizzz » Tue Nov 12, 2013 11:57 pm
Bryan Cotton wrote:None of our rivets are 3/32. That is just the size of the pilot holes. There is a table of these rivets at A/C Spruce.
Some are, they generally are used to attach things like nutplates.
rizzz
Users browsing this forum: No registered users and 83 guests
