by corton » Fri Oct 25, 2013 3:50 pm
Hi, Keith;
I didn't use any brackets. I have two hinge pins for each leg, inserted from the center of the fairing up and down, respectively. I drilled a hole in the bottom of the floor for the upper pin, and a hole in the wheelpant for the lower hole.
Carl
