by pappas » Sun Sep 13, 2020 12:31 pm
Fellas,
Do yourselves a giant favor when removing powder coating. It is heat that permanently adheres the paint to the metal. If you need to remove some, simply get out your $10 propane or map torch and heat the area you want to be cleared of the paint for a few seconds at a time. Then, hit it with a wire brush. It takes seconds to remove the PC that way. You will never go back to grinding or sanding.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
