Prince P-tip Carbon Fiber Propeller with AeroVee
Postby crahen » Fri Sep 11, 2020 12:02 pm
Hello,
I am in the process of building a new Aerovee to replace the current one in my Sonex, and I was considering a prop replacement as well. The Prince P-tip intrigues me, is anyone running the carbon fiber version of that? Any noticeable results or opinions on the combo? Thanks.
crahen
Re: Prince P-tip Carbon Fiber Propeller with AeroVee
Postby pappas » Fri Sep 11, 2020 4:52 pm
Are you building a turbo or normally aspirated engine? Although not finished yet, I have tested a few props this year on my Turbo Waiex B including 2 different pitch models of the P-tip.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby Curry Matherne » Fri Sep 11, 2020 9:06 pm
I have one new in box for my no turbo aerovee. I’ll give you some numbers after I finish installing my fuel injection system. The general consensus is that is a good choice. I’ll read the model number off it when I get back to the hanger.
Curry Matherne
Postby wlarson861 » Sat Sep 12, 2020 12:11 am
I ran the prince P-tip carbon covered prop on my normally aspirated AeroVee and thought it lived up to the advertising. I then upgraded to the turbo but went with the Sensenich cruise prop. The turbo was new and I didn't want to experiment trying to find the right pitch and diameter, so I went with the factory pick. I have now changed to a Jabiru and went back to the Prince P-tip. The performance is quite good. I think both props will do the job and will have similar performance though I think the Prince is a little better in climb. What it comes down to is the company it's self. When I had the first engine with a Prince prop I had a hinge pin from the cowl work out and go through the prop. It left the plane through the prop on final approach, leaving some dings and scratches in the prop. I sent an email to Prince asking if I could repair the damage or if I needed to send the prop in for service. Within 15 min of sending the email Lonnie Price called and wanted to ask about the extent of the damage. We discussed for a few min. and he told me how to do the repair and how to re-balance the prop. Performance being equal, Prince Aircraft is where I will spend my money.
Bill Larson
N861SX
wlarson861
Postby GraemeSmith » Sat Sep 12, 2020 5:52 am
P Tip - Order early - wait long was my experience. 8 months.
But I like the prop. Nothing to compare it to on a Sonex though.
Graeme JW Smith
GraemeSmith
Postby crahen » Sat Sep 12, 2020 10:22 am
pappas wrote:Are you building a turbo or normally aspirated engine? Although not finished yet, I have tested a few props this year on my Turbo Waiex B including 2 different pitch models of the P-tip.
Hello,
This will be a non-turbo engine.
crahen
Postby crahen » Sat Sep 12, 2020 10:23 am
Curry Matherne wrote:I have one new in box for my no turbo aerovee. I’ll give you some numbers after I finish installing my fuel injection system. The general consensus is that is a good choice. I’ll read the model number off it when I get back to the hanger.
That would be great, thanks Curry.
crahen
Postby crahen » Sat Sep 12, 2020 10:25 am
wlarson861 wrote:I ran the prince P-tip carbon covered prop on my normally aspirated AeroVee and thought it lived up to the advertising. I then upgraded to the turbo but went with the Sensenich cruise prop. The turbo was new and I didn't want to experiment trying to find the right pitch and diameter, so I went with the factory pick. I have now changed to a Jabiru and went back to the Prince P-tip. The performance is quite good. I think both props will do the job and will have similar performance though I think the Prince is a little better in climb. What it comes down to is the company it's self. When I had the first engine with a Prince prop I had a hinge pin from the cowl work out and go through the prop. It left the plane through the prop on final approach, leaving some dings and scratches in the prop. I sent an email to Prince asking if I could repair the damage or if I needed to send the prop in for service. Within 15 min of sending the email Lonnie Price called and wanted to ask about the extent of the damage. We discussed for a few min. and he told me how to do the repair and how to re-balance the prop. Performance being equal, Prince Aircraft is where I will spend my money.
Thanks Bill, great feedback and great service from Prince.
crahen
Postby crahen » Sat Sep 12, 2020 10:33 am
Did any of you get the Leading Edge Protection and/or tape options?
crahen
Postby GraemeSmith » Sat Sep 12, 2020 10:39 am
crahen wrote:Did any of you get the Leading Edge Protection and/or tape options?
Applied tape purchased from Aircraft Spruce. Follow the directions. Not too hard.
Graeme JW Smith
GraemeSmith
Users browsing this forum: petep and 58 guests
