gethomas wrote:Regardless of the needle# or screw position, I can not get the first trend you describe (rpm/EGT increase) trend you describe. Always get rpm drop and EGT decrease as mixture knob is pulled toward lean. With needle screwed CCW to engine running rough and black smoke I get the same rpm drop/EGT drop trend.
gethomas wrote:Always get rpm drop and EGT decrease as mixture knob is pulled toward lean.
gethomas wrote:Still can't get engine running correctly. With tunning I now have set, engine starts easily, runs smoothly, and takes full throttle without balking. Doing ground runs with cowling on, everything is ok until engine heats up (CHT 250up). Then engine quits when throttle is less than 1/2 open. It restarts but will not continue running a low throttle.
Any ideas on what's going on?
Users browsing this forum: Google [Bot], petep and 41 guests
