N21X wrote:Where is everyone installing pitch and roll servos in the Onex?
I installed both about a year ago. The roll servo is installed on the right side (pilot's perspective) of the floor just forward of the main spar. (It could have been installed on the left side.) In that position it is out of the way and almost impossible to step on it or kick it.
The pitch servo is installed on the right side of the floor (pilot's perspective) just aft of the rear spar carry thru.
Here is an email I sent to another OneX builder who asked a similar question.
I took some photos of my roll servo installation. I couldn’t get great shots because it was difficult to place and point the camera in such a tight space.
https://jasflyer.com/cabinheat/Bell%20Crank.jpg The silver oblong piece in the middle of the picture is a bell crank I fabricated from 1/8" thick aluminum. It is designed to be connected to ONX-C03-10. When I made this piece I didn’t know how far below the pivot point the servo push rod would need to be connected. As you can see I drilled 4 holes. I ended up using the top one. The lower holes resulted in over control by the servo. So the lesson I learned that I can pass on to you is: your bell crank will only need to extend about 3 inches below the bottom of ONX-C03-10. I suggest you drill more than one hole, then experiment to find the one that gives you the correct servo/control response.
https://jasflyer.com/cabinheat/Roll%20Servo.jpg It was very difficult to get a good picture of this because the control stick frame (ONX-C03-03) blocked the view. (In practice this is a good thing, because the control stick frame also covers and protects the servo from being stepped on!) You’ll want to place the servo as far right as possible. This provides the best geometry for the servo push rod. Also place it as far back as possible. Keep in mind where the electrical connector is. I had a devil of a time screwing mine in because it is so close to the spar.
I custom designed and fabricated the servo mount tray. It has three sides and no bottom. The servo connects to the front of the tray using the mounting hardware that came with the MGL servo. At the bottom of the three sides are ‘feet’ bent away at a 90 degree angle, which are then riveted to the fuselage floor.
I’d estimate it took me about 1 hour to fabricate the bell crank, 2 hours to fabricate the tray and another 2 hours to install the whole mess in the plane.
Let me know if you have any questions. Good luck.
