Rynoth wrote:I mounted my RDAC and main fuse panel on that upper portion and it works just fine, here's a picture of a mockup of my firewall with the engine removed.
The only real concern is that you have enough space between the fuel tank and upper firewall for your nutplates/screws, and I found I had plenty of clearance for this.
pfhoeycfi wrote:Did you have any issues with your RDAC location when you installed the turbo & turbo cooling. I'd like to rivet a couple of rails (sq tube) in that location now in order to mount the RDAC at a later date...so that I can put the glareshield and tank in now. Engine etc is on order but I want to keep moving.
peter
pfhoeycfi wrote:Rynoth wrote:I mounted my RDAC and main fuse panel on that upper portion and it works just fine, here's a picture of a mockup of my firewall with the engine removed.
peter
Users browsing this forum: Capt T and 13 guests
